Floating Trailer Issues
Old 10-18-2013 | 01:18 PM
Default Floating Trailer Issues
I have a Hi-Tech Marine aluminum trailer which always floats. While I can overcome the issue by standing on it while the lady loads it I was curious to what others do to keep it submerged.
Best idea I have thought of was to get old lead diving weights and fix them to the frame. I searched for a commercial product and couldn't find anything available.
Ideas?
Sunny32SSR is offline
Old 10-18-2013 | 01:24 PM
I had the same problem with an aluminum boat lift. Two solutions, change out the wood bunks to aluminum bunks, or add more weight, I went for the 2nd and added concrete. Good luck
kjkam is offline
Old 10-18-2013 | 01:35 PM
buy two pvc tubes about 6 inches in diamater and about 4 feet long, fill with concrete and strap to the insides of the wood bunks
pslonaker is offline
Old 10-18-2013 | 01:39 PM
MidOcean's Avatar
This is why I prefer a tandem trailer....
Eastern Metal Supply has a square tube material that is designed just for trailer bunks.
Here is their PDF
http://www.easternmetal.com/pdfs/ems...plete_BOAT.pdf
MidOcean is offline
Old 10-18-2013 | 01:54 PM
Sydwayz's Avatar
Forum Regulator
Eastern Metal Supply has a square tube material that is designed just for trainer bunks.
Here is their PDF
WTF are you talking about?
Sydwayz is offline
Old 10-18-2013 | 01:55 PM
Sydwayz's Avatar
Forum Regulator
Several posts on this topic with good solutions.
http://www.offshoreonly.com/forums/s...earchid=336617
Dumbells and U-bolts worked for me.
Sydwayz is offline
Old 10-18-2013 | 02:47 PM
All the above will work. We have a easy no cost process. Back in the trailer in but not so far in that it floats. Drive the boat about 1/3 way up the bungs and the driver walks down the trailer with the wench strap in hand & connects. Driver eases the trailer into the water while you are cranking in the winch strap....pretty easy. Wife can't help?...maybe your girfriend can.
BenPerfected is offline
Old 10-18-2013 | 03:58 PM
I back up slowly to let the air bubbles escape from the trailer cross members and other nooks. Then I can go all the way back. Sucks when the trailer floats under the dock!
thirdchildhood is offline
Old 10-18-2013 | 04:33 PM
Smitty's Avatar
I have a bunch of lead in round shape and bar shape that I need to sell for heck of a deal. Probably have 250 lbs or more.. We melted it into the corners of race cars to acheive perfect weight balance. PM me if interested
Smitty is offline
Old 10-18-2013 | 04:48 PM
Had a customer with the same problem. He made an aluminum bracket in the shape of a U and bolted it to the sides of the trailer near the rear. On those brackets, he would hang John Deere tractor weights that would go on the front of a tractor. You take them off when not needed. Worked great.
Eddie
Young Performance is offline
