Looking at a hynautic hydro steering kit..explain it all to me... >
Old 10-25-2013 | 07:38 AM
Default Looking at a hynautic hydro steering kit..explain it all to me...
I am looking at a used set up to add on to my Baja. The kit came off a 31 footer, that had twins, I only have a single, so the set up has two rams. Can I use both rams on the single, one on each side of the outdrive? Explain the hynautic set up to me..I heard it doesn't use a power steering pump? Is it a good set up for a performance boat? Or is it more of a houseboat set up? The kit that Im looking at doesn't have the swivel ends on it, it has the ball and rod end type, can this be converted?
stlliberator is offline
Old 10-25-2013 | 09:55 PM
anyone???
Old 10-28-2013 | 11:48 AM
I had a hynautic on my old boat, set up myself with twins. I would say you do need swivel joints, because as the outdrives trim up and down you will need the added movement.
And correct, you dont need a power steering pump, its an air pressurized system. Careful what helm you get because some are none to have MANY turns, left to right, too many infact. I had the H42 model and wouldnt suggest any of the lower ones. You can use 2 rams on a single outdrive as well.
Rambocj7 is offline
