Best Gaskets >
Best Gaskets
Best Gaskets
Old 10-27-2013 | 10:03 AM
Craney's Avatar
Default Best Gaskets
I'm building new motors would Fel-Pro gaskets be the best to use for the oil pan,timing chain cover and intake gaskets or is there something better that don't leak ??
Craney is offline
Old 10-27-2013 | 10:40 AM
Felpro is a good gasket but it depends what intake you use. I use edelbrock aluminum intakes so I use Edelbrock intake gaskets. Seals better.
f_inscreenname is offline
Old 10-27-2013 | 11:07 AM
i dont use or recomend useing any intake gasket that has the silicone around the port.i like the mr gasket intake manifold gaskets,i put a smear cote of the right stuff on the head and the manifold and never had a problem.the fel pro line of gaskets is also good imo.
mike tkach is offline
Old 10-27-2013 | 11:51 AM
GPM
Cometic makes a nice intake gasket.
GPM is offline
Old 10-27-2013 | 03:29 PM
I use Fel Pro MLS for my head gaskets, a Fel Pro 1pc "non crush" oil pan gasket, Mr Gasket intake manifold gaskets, Fel Pro timing cover gasket and Fel Pro exhaust gaskets.
mustangmark is offline
Old 10-28-2013 | 08:40 AM
What do you think of these Mike :
http://www.goodvibesracing.com/ics_copper_gaskets.htm
ICDEDPPL is offline
Old 10-28-2013 | 09:24 AM
Originally Posted by ICDEDPPL
You wouldn't want to run those. MLS cometic or FEL Pro MLS are the head gasket of choice in marine boosted applications.
MILD THUNDER is offline
Old 10-28-2013 | 01:22 PM
i agree,big boost alcohol engines require a o ring and a reciever groove,low boost[15 lbs or less]a mls gasket is all you need.i have used fel pro marine gaskets on 1000 hp marine engines in the past,but the mls gaskets are now the way to go.
Old 10-28-2013 | 03:38 PM
hmmm I think I`ll ask my friend Jack what he thinks..
ICDEDPPL is offline
Old 10-28-2013 | 06:14 PM
rutro,thats some funny chit,what works on everything else wont work on a 42 fountain,lol.
