EMI Exhaust comparison
How does Eddie Marine Exhaust manifolds compare to Stainless, Imco, Dana or Hardin/Gills? Are they similar in quality/ performance? Any help wiuld be great, thanks
502 mpi with a Bob Madera cam and some head work and lower intake Right around 500-515hp. Going to use a long riser system, just curious wondering if it is worth it to pay more for the Stainless or Dana with the Vortex long risers
Depends on whio you talk to..they all are about the same...eddie use's a hard anodise on theirs which makes them last longer..and they are goo manifolds,you just have to mess around with theps pump hose,,give it a little ore bend anf run it up along the intake manifold and valve cover.... if you dont have captains choice i would get the long tails,,sound killet wicked and look alot better,just make sure you order their rings and ask chris to install internal flappers so you dont have to install the Salisbury style flapper..they can also angle cut the pipe for you..
The power stering pump on the port side,,the high pressure hose's fitting will hit the front of the manifold....the fitting is at a 45* angle,you have to make it a 60* bend in the fitting and loop the hose so it runs towards the front of the cylinder head and along the top of the intake where it meets the cylinder head..they fit tight..
