Winter projects, looking for tips, tricks, advice.... >
Old 11-09-2013 | 12:13 PM
Default Winter projects, looking for tips, tricks, advice....
Converting the boat from a stand up to a sit down. Have the seats ordered, similar to sparcos etc. and I am going to make a console between the seats for the controls, stereo and switches. Removing the factory dash pod and placing gauges across the center of the dash.
Since I am moving all the switches, gauges etc, and would most likely have to do a ton of splicing, slicing and dicing to the wiring (which already looks like a crack addict took a machete to). Would it be easier to buy a new merc harness, some wire and just rewire the whole thing? What size wire do I need etc?
Next I have a set of zero effort controls out at the chromers, the cables come up from the bottom. This is a challenge because there won't be a whole lot of room under them. Is there a kit out there to deal with this or tricks to making it work? More flexible cables avail?
Going from this to something like this...
phragle is offline
Old 11-09-2013 | 03:30 PM
One thing I can suggest is just make sure your seats are high enough so you can see above the windshield if needed, but not to high that your feet dangle like a kid in a high chair..
stlliberator is offline
Old 11-09-2013 | 03:51 PM
Yea I had a 22 avanti, really was to low freeboard for Standup. What are you going to put on it for power?
21eagle is offline
Old 11-09-2013 | 03:59 PM
stock 7.4 mpi right now, runs good. Bigger motor is next winters project.
phragle is offline
Old 11-09-2013 | 04:06 PM
glassdave's Avatar
Neno the mind boggler
I would find a local shop, one that maybe parts out boats or ends up with old take off parts. Befriend them . . . . bring'em lunch once in a while. Maybe they have some deals on spare stuff. . . .
08 OPA High Points Champion
glassdave is offline
Old 11-09-2013 | 04:16 PM
ROFL!!! And has a bigger faster boat to take you out on when yours is in his shop?? I'm really beginning to figure this stuff out!!!!
phragle is offline
Old 11-09-2013 | 05:15 PM
I thought you were going outboard run class 7? Changed plans?
21eagle is offline
Old 11-09-2013 | 05:20 PM
yep, would need a 300 ob to be competitive, significantly more expensive than a 250. Also after running it on flat water and some lumps, it would be rather sedate for general use with an ob.
phragle is offline
Old 11-09-2013 | 06:32 PM
Yea I wouldn't do it. With the big block prob runs mid 60's? A hot small block would be nice less weight
21eagle is offline
Old 11-09-2013 | 07:10 PM
Shoot me a pm if you decide to sell the bolsters. I am looing for an old school set like yours.
Steve
Katanna is offline
