Seawater/fuel pump mounting bracket for V-belt? >
Old 11-10-2013 | 12:53 AM
Default Seawater/fuel pump mounting bracket for V-belt?
Trying to finish my 509 project and the sea water/ fuel pump will not fit in the mounting bracket? Itis slightly too big around? I bought my boat with no engine and had a core gen V 454 given to me with accessories. from my research It looks like 1 style of pump braket was used with the v- belt setup but the seawater/fuel pump I bought here is a 1 piece housing and no way it will fit. Is there another style bracket that was used? Mine has just 4 bolt holes I think this one used the old style 2 piece pump housing?
I don't have a lot of experience with this stuff so I need some help! I don't want o spend $500 or more for a new pump?
Thanks in advance...... TBF
tpabayflyer is offline
Old 11-10-2013 | 08:48 AM
Post a picture of what you have. I have a coupe different sets I bought for backup parts that I can post of pic of..
1BIGJIM is offline
Old 11-10-2013 | 11:21 AM
Thanks Jim, I am not sure how to post a pic but here is A link to the diagram of the mounting setup I have...... Thanks...... TBF
http://www.marinepowerservice.com/Bo...pickyear/0.cfm
Old 11-10-2013 | 02:18 PM
the pump goes on backside of bracket, ports are normally up and down(suction-bottom, discharge-top). I prefer to put pump on bracket then position on engine, better to tighten bolts, less chance of cracking housing.
keith2500hd is offline
Old 11-10-2013 | 03:00 PM
Yes, I figured it goes on the back and it looks like it lines up real nice with the center of the triple pulley....... the pump has 5 mounting bolts yet the bracket only has 4? it looks like if it were to actually fit then maybe 3 bolts could be used but is sets the fuel pump almost vertically? I got something wrong here for sure.... I cant post pix but maybe can someone send me a PM or email that I can send a pic for posting? my email is my screen name at the yaahhoo site......thanks... TBF
Old 11-10-2013 | 04:01 PM
Here is a link to the seawater/fuel pump I have now...... Looks like a gen 5/6 502 carb motor........
http://www.michiganmotorz.com/mercru...502-p-751.html
Old 11-10-2013 | 04:02 PM
So the big question is, what mounting bracket will work with that pump?????
Old 11-10-2013 | 06:51 PM
yes the fuel pump is on top not side. make sure to fill cavity with gearlube. the drain plug should be on outboard side. the impeller/housing kit comes with long and short bolts.
Old 11-10-2013 | 07:37 PM
All the pumps I have seen have been mounted horizontal?? but this bracket will not work. Here is a pic, I just upgraded my membership so mow I can post..... TBF
Old 11-10-2013 | 07:41 PM
Well, it says I can upload but no go...... wtfo? .......
