Hub adapter for old fountain dash up grade >
Old 11-19-2013 | 10:47 AM
Default Hub adapter for old fountain dash up grade
Hello, I have a 1991 32' fountain, which I am trying to finish up the dash. I am trying to find an adapter to go from the old school three screw steering wheel to a modern wheel. I have ordered two adapters, one from Hardin marine and one from Livorsi. Both have been wrong. Any help will be appreciated. Below is a pic of the old wheel and a pic of the back of the new adapter. Sorry, I do not have a pic of the old wheel back.
https://www.dropbox.com/s/ty0wljknzk...Hub%20back.jpg
https://www.dropbox.com/s/6z79qvc795...20dash%202.jpg
joew. is offline
Old 11-19-2013 | 01:15 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Are you keeping the CRT unit? If so, I believe the wheel bolts to it, no adapter used there. Been several yrs ....
US1 Fountain is offline
Old 11-19-2013 | 01:19 PM
No I pulled it. I found an adapter, square on one side and three bolt on the other. It got me to the point I am at now. I just ordered another adapter from gaffrig which I am hoping will be the last one. Thanks.
joew. is offline
Old 11-20-2013 | 08:53 AM
you should be able to remove the steering wheel with the hub assembly as a unit and install a new hub and wheel,,,
thats all I did
boatnt is offline
Old 11-20-2013 | 11:00 AM
I have an older boat which has the square style of steering. I thought I had it covered through Gaffrig but it turns out the adapter is obsolete and no longer available. I now have another hub coming from Harden which is going to use the old hub adapter and go from a three screw to a six screw. Man, what a pain in the azz. Hopefully this will work. If not, I am going to have one made at my plant, should have done this last month.
joew. is offline
Old 11-20-2013 | 01:10 PM
Ginger or Mary Ann?
It's a sign to install hyd steering
Old 11-20-2013 | 01:44 PM
It is a old school mercruiser hyd assisted mechanical system. Someone else can explain how it works, but it looks like a hyd system on the drives and it works very well.
joew. is offline
