CMI HEADERS 700 BOAT LEAKING NEED lOPTIONS >
Old 11-19-2013 | 08:09 PM
Default CMI HEADERS 700 BOAT LEAKING NEED lOPTIONS
07 model 700 motors headers are leaking OMG new ones are out of sight
Had them fixed once by CMI
back motor rite side leaking again
What would you do or have you done about this problem if anyone can give some advice
gnorthga is offline
Old 11-19-2013 | 09:40 PM
Perfect Storm's Avatar
In my opinion, you should replace the CMI's ASAP. It's better to replace them now BEFORE you smoke one or both of your motors, because then you'll be spending a lot more $$$ on motor(s) and you'll STILL need to buy new headers! If you keep repairing them you're just chasing your tail and risking your engines in the process. I know it sucks (!) because I had to deal with the same issue in 2011 with the CMI's on my '03 525EFI's with only 135 fresh water hours on them... I just bit the bullet and replaced them. It made me extremely upset that I had to spend that kind of money on new headers that I NEVER thought I'd have to replace (AND SHOULDN'T HAVE HAD TO) but smoking one or both of my motors (because of leaky headers) would have been FAR worse!
Peace is that brief glorious moment in history when everybody stands around reloading.
Perfect Storm is offline
Old 11-19-2013 | 10:17 PM
This place saved my big tube headers. Superior Welding Punta Gorda FL 941 639 2966
Or buy new AFTER MARKET CMI's. Don't buy the Mercury. You will see that After-markets are heavier.
Offshore Performance Specialties Fort Myers FL (239) 489-0884 call Donney he has very good prices.
Kat Krazy is offline
Old 11-19-2013 | 10:41 PM
Expensive Date's Avatar
http://www.cpperformance.com/p-16690...dard-exit.aspx
While I do not have 700,s or CMI's on my boat if I did this is what I would do.
Expensive Date is offline
Old 11-19-2013 | 10:48 PM
Gladhe8er's Avatar
Perfect Storm is 100% correct. I have lost a couple of seasons because of those stupid headers. I replaced them last year with stainless marine headers.
Gladhe8er is offline
Old 11-20-2013 | 05:56 AM
Indy's Avatar
Member #154
How that company hasn't had a class action lawsuit is beyond me. Without question one of the worst high performance boating products to ever be marketed. I'd replace them with anything other than CMI.
Indy is offline
Old 11-20-2013 | 06:11 AM
Just curious, did you pressure test the headers and found the leak? or was it something else...
I have the same motors, seeing things like this makes me nervous
bjablonski is offline
Old 11-20-2013 | 06:21 AM
Perfect Storm
Did you go back with CMI mercury headers or did you get non mercury CMI headers.
A good friend of mine said CMI headers are fine just dont get the ones mercury has CMI build to there specs.
If you put mercury CMI on did you have any trouble after you installed the mercury CMI new headers?
gnorthga is offline
Old 11-20-2013 | 06:39 AM
I talked to Donny yesterday, great guy to talk to about boat parts his dad Don Carter was a big time boat racer back in the day.
Donny said mercury improved there headers in 09 re-did the collector area and its been 4 years and he has not saw any go bad but OMG he wants $5500 a set x 2 $11000.00 I am now saying I cant afford them I just think thats a little high for 2 sets
gnorthga is offline
Old 11-20-2013 | 06:51 AM
Listen i have owned this boat going on 4 years and i know how to keep it running for a complete season
during off season
1. pull out all fuel injectors get flowed
2. pressure or water test headers
3. remove all old fuel
3. replace water pumps and change oil in fuel pump assembly replace mechanical fuel pumps if gas is present
4. leak motors down
5. if seaweed is present in intercoolers remove and send to radiator shop or re-install (install better sea strainer just for intercoolers to end this process.
5. new mercury fuel filters and water separators.
This is annual maintenance every year to keep from breaking down in the middle of a season when I do this ever year we are able to make it to 6 or more poker runs a year and play on our lake 95% time trouble free
gnorthga is offline
