trim transducer
Old 08-09-2002 | 10:22 AM
RUSSSR1's Avatar
Default trim transducer
I have a trim guage acting up it is pined high and sometimes drops down. I found a section of bare wire coming out of the transducer on the drive. Could this bare wire be shorting on the drive causing my problem? I assume that the new transducer will have a length of wire on it. Were is the best place to make the splice or is there a plugin somewere? how is the wire sealed through the transome?
Russ
RUSSSR1 is offline
Old 08-09-2002 | 11:25 AM
Its all one assembly with the wires. They go through the transom assembly and plug in on the inside. Its a pain in the a$$ to replace as most times you have to take off the drive to do it. The bare wire would cause this. You could try cleaning the wires and coating them with liquid electric tape.
Griff is offline
Old 08-09-2002 | 11:48 AM
RUSSSR1's Avatar
Can you cut the old wires and use them to fish the new wires through? What seals the transome were the wires go through?
Russ
RUSSSR1 is offline
Old 08-09-2002 | 11:57 AM
mcollinstn's Avatar
the ones I have replaced in the past were easier to cut the wires and solder the new unit to them. If your sender is okay and the wires are rubbing, then spread some 3m 5200 fast dry (in black, of course) over the wires and smooth the coating with a wetted fingertip. Leave the coating fairly thick and let it set up. 5200 will not peel off of the wires (be sure to clean the old wires first with alcohol).
Cheap easy fix.
mcollinstn is offline
Old 08-09-2002 | 12:04 PM
RUSSSR1's Avatar
I will try this. In the winter I am doing indicators for tabs and drives so I would not like to do a lot of work on this.
Russ
RUSSSR1 is offline
morgansrun
0
07-02-2007 05:15 AM
JeffC
Cigarette
3
03-30-2007 03:43 PM
TOMMY HIWAVE
Fountain
8
05-18-2005 12:49 PM
rwoods
Powerquest
19
07-12-2003 11:23 PM
Scarab3DMC
07-04-2002 09:54 AM
