Msd 8728 Rev Control Wiring
Official OSO boat whore
RED-to switched 12v source. I used the coil positive.
BLACK-ground
GREEN-to coil negative
WHITE-to coil negative
VIOLET-not used. I recommend looping this back on it's self and sliding a piece of shrink tube over both wires. Makes for a very clean termination.
BLACK-ground
Cord,
Are you saying that the green & white go directly on the (-)coil post and the red goes on the (+)coil post along w/ the wires that come from the distributor?
I guess I was thinking the wires from the distributor would go through the rev limiter on their way to the coil.
Thanks for the reply, would like to get this thing on tommorrow morning.
Bill, that sounds like the way mine was hooked up. Nothing went to the distributor, only the coil. That I'm sure of.
MSD shows the wires being spliced, but I just connected them to the coil posts and it work fine.
Tinker-I'm not sure what "little black thing" you are refering to. Can't think of it at all...
BGIII-If you are refering to the merc wires, they go to the distributor. The post is labled as to what wire goes where. The msd green and white wires do go to the coil negative.
I am running theese same MSD limiters on a TB4 ignition, I know they are wired right. No mater what RPM chip I use I can only get 4500 RPMs out of either engine, if I do not have a chip in I get my usual 5200Rs @WOT
Does any one have any suggestions on this?
