which 502 do I have? it sure would be easy if a parts vendor added a search engine! >
Old 12-04-2013 | 08:59 PM
Default which 502 do I have? it sure would be easy if a parts vendor added a search engine!
serial tag is D845014 block casting looks is 14096859
trying to determine year generation etc
thanks in advance
stimleck is offline
Old 12-04-2013 | 09:26 PM
block is 502 ho gen5 thats all i can come up with.
mike tkach is offline
Old 12-04-2013 | 09:53 PM
here you go....
enter your serial number
https://webapps.brunswick.com/litera...atureSearch.do
phragle is offline
Old 12-04-2013 | 10:50 PM
You don't need a serial number for that info.
If it has a fuel pump mount on the engine block, its a Mark IV
If it has no fuel pump provision and a stamped steel timing chain cover, its a Gen V.
If it has no fuel pump provision and a cast timing chain cover, its a Gen VI
Griff is offline
Old 12-13-2013 | 09:58 AM
also the gen6 only has 6 bolts on timing chain cover.
Old 12-13-2013 | 10:09 AM
Marineengine.com
Chose search by serial range. Simple to use.
Baja226sport is offline
