water crossovers pros cons
looking into water crossovers for my 572's some guys seem to like the bypass style and some do not. any pros and cons to either? other than running a thermostat
ran my 500hp without a stat and bypass, never got over 100, switched to bypass and 140 stat, ran 150 after that...helps burn off condensation in the oil...you could run a thermostat on the oil cooler as well...
i run cross overs on mine and inorder to get the temperature i want i used a ss washer to act like a restrictor insted of a thermostat. Thus holding water in the block longer to gain temperature. After experimenting with sizes i got it right on the money.
