Can a 496 be damaged with freezing temps?
I have a friend with a 496 mag ho. He stores this boat inside every winter but this year was slow to tow it to the storage facility. With the boat sitting outside we had hi/low temps of 32/19, 34/24 and 34/23. I would assume the block is safe but the manifolds? Heat exchanger? Anything else he should be concerned with?
If you are unsure, go to Petsmart and get 2 (or 3) clip on Lizard heaters. You clamp them on and either put them on a lamp timer or leave them on.
You will be surprised when you check on your boat and the engine is WARM...
Agreed. Doesn't take much to freeze the small amount of water in engine blocks acting like freezers!
I have antifreeze in my exchanger this time of year.
