Carb was stolen while in storage. Carb no longer made... What replacement??? >
Old 12-13-2013 | 09:16 AM
Question Carb was stolen while in storage. Carb no longer made... What replacement???
I just found out that the storage warehouse where I keep my boat at was broken into, and the carb was stolen off my engine. The carb was a 850 Mighty Demon Marine (5563010GM) which is no longer made.
At the end of this summer I finally figured how to tune the carb perfect, and had the engine running awesome!
Can anybody recommend me a good replacemnet carb?
Engine is a 502 built by Tyler Crockett. Ported Dart Pro 1 heads, Merlin Intake, Lightning headers, Water pump cross over, Full MSD ignition. Dyno at 610 HP
Thanks!!
JackLS1R1 is offline
Old 12-13-2013 | 10:00 AM
Wobble's Avatar
SORE MEMBER
Thanks!!
I'd call my engine builder if that's an option,
Otherwise this is very similar http://www.ebay.com/itm/like/121216943374?lpid=82 Had good luck with quickfuel
or this http://www.ebay.com/itm/like/400303449898?lpid=82
Wobble is offline
Old 12-13-2013 | 10:28 AM
Wobble's Avatar
SORE MEMBER
been reading some good reviews about these carbs too http://www.ebay.com/itm/like/161160905879?lpid=82
Wobble is offline
well if the insurance is paying?? call s&s in missouri..get a aresoll carb..they rock amd vary responsive..
FIXX is offline
Keep an eye on the local craigslist-may get yours back.
Katanna is offline
Old 12-13-2013 | 10:45 AM
i might have what you need,i bought one from oso member this summer and put in on the shelf,if you are interested i will check and see if it is the one like you had.
mike tkach is offline
Old 12-14-2013 | 01:19 PM
Well insurance is paying and I am liking what I read about the Quick fuel and AED.
They also took the distributor (MSD marine) and Fuel Pressure regulator (Aeromotive). Any upgrades for these? lol
Thanks again
Old 12-14-2013 | 01:24 PM
One thing you need to check is what happened to all of the nuts, washers and all holding these parts on. They do not do very well when they fall down the intake and distributor hole and can really cause problems. I am sure they did not watch what they were doing and remove it carefully.
fountainboater is offline
Old 12-14-2013 | 02:23 PM
http://www.quickfueltechnology.com/c...arburetor.html
MILD THUNDER is offline
Old 12-15-2013 | 08:17 AM
jvthundercat's Avatar
Only good answer for that is Borescope. Make sure the insurance is paying for the 3 hours of having that done to prevent more damage.
jvthundercat is offline
