my head work begins
Old 12-14-2013 | 06:42 PM
Default my head work begins
Just another prop testing day and then trouble,reversion,. Tell me what you think of these pics.
[ATTACH=CONFIG]514250[/ATTACH][ATTACH=CONFIG]514251[/ATTACH][ATTACH=CONFIG]514252[/ATTACH][ATTACH=CONFIG]514253[/ATTACH][ATTACH=CONFIG]514254[/ATTACH]
Attached Thumbnails my head work begins-timmy-dec14-030.jpg   my head work begins-timmy-dec14-034.jpg   my head work begins-exhaust1.0-001.jpg
my head work begins-exhaust1.0-002.jpg   my head work begins-exhaust1.0-003.jpg
nautimarine is offline
Old 12-14-2013 | 07:17 PM
Tinkerer's Avatar
OUCH - looks like junk, buy a set of aftermarket aluminum heads. OH I see you are in Flor I da. Maybe not aluminum. But definitely after market.
Tinkerer is offline
Old 12-14-2013 | 07:28 PM
Im gonna grind them some and see how they turn out surprisingly valves didn't leak and seats look good. Ill post picks when they cleaned up.
Old 12-15-2013 | 04:36 AM
That didn't happen overnight.
Rattlesnake Jake is offline
Old 12-15-2013 | 04:43 AM
just give it an acid bath. it will clean all that rust off without countless hours of grinding.
http://www.volkstorque.co.uk/vt/tech...rust-bath.html
dip anything else you have into that bath as well. one change on those instructions, never add water to an acid... always an acid to water. when you're done with the bath just dilute it with lots of water to safely get rid of it. its not terribly acidic at all.
ka0tyk is offline
Old 12-15-2013 | 08:32 AM
Funny, I have a huge bag of that acid at my shop that i use to clean the bottoms of boats, time to play with some acid
Old 12-15-2013 | 09:01 AM
Timothy Leary would be proud!!!
phragle is offline
Old 12-15-2013 | 09:02 AM
i would not reuse those heads,to much rust espically if they are peanut port heads as they are a dime a dozen.
mike tkach is offline
Old 12-15-2013 | 09:08 AM
They are 088 heads and the pic looks a little worse than it really is and that is the worst. Hopefully i can save it and fix my reversion problem also so I don't do this again. I'll post more pics when i clean it up.
Old 12-15-2013 | 10:51 AM
Mike peanut heads are now in high demand due to OSO, prices have shot way up
Those heads look like scrap to me.
ICDEDPPL is offline
