Stainless bolts thru aluminum
I bought stainless bolts for my bellhousing. Even thou the bolts go into the engine block I`m not sure if thats safe to do ?? Stainless and aluminum dont like each other correct?
ICDED my bravo bellhousing had SS bolts in it from merc, in fact every bolt in the motor (ext head bolts) are SS bolts, and if your using SSbolts and SSNuts together make sure you use antiseeze if you don't they could guild up....
Why not use grade 8 bolts and grease the threads? The gold plating is either cad or zinc and will rust but they are a lot stronger than the stainless bolts.
Are stainless bolts strong enough for a bell housing application?
I think its more of an issue when submerged in water, like your aluminum drive that has SS studs and nuts. That's were you'll always see the corrosion start
Try this, http://www.totallystainless.com/Catalog.html the company name is totally stainless, get all my stainless steel bolts, nuts, washers from them, they also list them by strength from grade 2/3 to stronger than grade 8, the grade 8 or stronger are ARP bolts and TS bolts and you can buy all items in any amount of the different items you want....
