Go Back  Offshoreonly.com > Owners Forum > Nordic
Just bought a heat outdrive and propping questions? >
Old 02-06-2014 | 08:55 PM
Default Just bought a heat outdrive and propping questions?
I just bought a 97 28' heat MCOB and am currently having a motor built for it and should be around 600 horse, just curious about what prop do you think I'll be able to swing? Do you think a nose cone on my stock bravo 1 drive would be worth buying? Also I've been reading on the drive spacers? And last what kind of speed do you think I should see out if it? This is my first nordic so I'm always eager to learn. Thanks Brent
Bbeck is offline
Old 02-07-2014 | 03:53 AM
I'm running a 2000 Heat with a 502whipple charged 600+hp, bravo 1xr, labbed 28 bravo, and hitting 74 @ 5100rpm. I'm getting a lot of prop slip and Ben thinking about the nose cone as well. If this
FKNMKE is offline
Hope that helps you out
FKNMKE is offline
Old 02-07-2014 | 08:12 AM
Yes that is helpful, Are you running any drive spacer? That may help with the slipping
Bbeck is offline
Old 02-07-2014 | 08:16 AM
What ratio is your outdrive? If it's a 1.50 an your numbers are all accurate that's around 18% prop slip
Bbeck is offline
Old 02-07-2014 | 11:09 AM
Ratio is 1.50, no drive spacer yet.
FKNMKE is offline
Old 02-08-2014 | 08:45 AM
Steve Zuckerman's Avatar
Best way to reduce your slip numbers are a 1" drive spacer and/or a 5 blade propeller.
Steve Zuckerman is offline
Old 02-08-2014 | 10:16 AM
Thanks for the in put, what 5 blade prop do you recommend?
Bbeck is offline
Old 02-09-2014 | 08:49 AM
My 98 heat had a lower x dimension then the newer boats with the step, it always ran best with non labbed stock bravo props. My friend that has it now put a 2" shorter imco lower with 1" spacer and it gained a couple mph in the upper 80's and lost a few at cruise but it did make the boat more stable at top speed with the shorter drive height, it always had great cruise speed that is why I never raised it but it did want to chine walk at top speed. We have tried my 5 blade p5x and my Maximus prop on it and it lost speed with both but my 2010 heat is faster with the 5 blade props.
sport is offline
Old 02-09-2014 | 10:22 AM
I have run P5-Xs on my boat with good success right out of the box. I have a 29" worked by Throttle up and a 30" worked by Herring.
They are both great props. Other designs like the Maximus can work too, but it's going to take more customizing.
A friend has a 30" 5 blade Herring that runs really well on his Heat. I've never run it..
The 5 blades work well on step hull Heats because the X dimension is high, leaving very little submerged blade area in the water to lift our relatively large singe engine boats.
Mine are very stable at all speeds.
