water temp sending unit?? >
Old 08-13-2002 | 11:56 AM
dyno's Avatar
Charter Member #655
Default water temp sending unit??
are the sending units for electrical gauges the same????is it a merc part or do you need to get the one that goes with your type of gauge???
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 08-13-2002 | 12:08 PM
ursus
You need one that matches your guage, water temp are mostly of the 240-33 ohm type but there are others. VDO are different as are some other brands and there are dif ranges 220degF 250 degF etc. Oil temp senders have even more flavours.
Wally's Avatar
Were doomed!
Depends on the gauges your useing. I know the merc stuff should work with the Gaffrig stuff. But VDO wont. neither will the OMC senders with Gaffrig. I found that out after redoing the dash on my dads deck boat. Gauges were acting WAY goofy. And i thought OMC was a division of Merc or maybe they used the same stuff here and there! Oh well...
-Wally
Wally is offline
Interceptor
Fountain
4
05-16-2008 06:40 AM
Interceptor
0
05-14-2008 08:58 AM
Velocity Vector
16
12-31-2007 10:06 PM
Wooderson
5
04-13-2007 04:34 PM
fred
2
06-24-2002 09:41 AM
