procharger fuel system help fuel regulator >
Old 02-18-2014 | 02:59 PM
Default procharger fuel system help fuel regulator
I recently changed out my fuel system got rid of the procharger regulator and added a Aeromotive 1 to 1 along with a high flow fuel pump and bigger fuel lines . I have a Mefi tunning program and was wondering should I be tunning using the 1:1 regulator which is increasing fuel pressure 1 psi to 1psi of boost. Or do I just leave the fuel pressure constant and tune for extra fuel through the MEFI ?? . It is a 454 Mag efi running 5-6 psi of boost. I also use a 2 bar Map sensor to capture the boost . As of today it is tunned for proper air fuel using the 1to regulator ?
THX
Plus Man is offline
Old 02-18-2014 | 03:24 PM
GPM
Use the regulator to increase the fuel pressure to the injector to offset the boost pressure in the manifold that's pushing on the injector.
GPM is offline
Old 02-19-2014 | 07:08 PM
that's sounds great but how do you get to a safe afr like 11.8 or 12 to one when boosted at max rpm since the mefi is operating outside its ability to read
nitrouspaul is offline
Old 02-20-2014 | 01:42 PM
GPM
No clue on the MEFI, I run the Fast system, I like to tune in real time. I was just answering the regulator question.
GPM is offline
Old 02-20-2014 | 01:59 PM
Fuel pressure through a boost-referenced regulator that is not 1:1. Very tough to tune one and they are inconsistent day to day with varying weather conditions. Just right one day, fat the next....BOOM the day after that!
Griswald is offline
