Vessel view codes? >
Vessel view codes?
Vessel view codes?
Old 02-20-2014 | 01:14 PM
Default Vessel view codes?
Anyone knows what this means? (525 EFI)
I have an "active alarm".
"PTOT CKT LO"
WHat on earth does that mean?
Thx
P
PARADOX is offline
Old 02-22-2014 | 03:39 AM
Question
PTOT CKT LO"
Are you sure it did not say PITOT CKT LO? Code is active
Pitot ckt lo is a code you will get if the pressure transducer for the electronic water pressure gauge is not being used (plugged in) or if it is being used, be sure there is no interference from the sensor wire harness being to close to the spark plug wires as that could through an active fault.
You may find the link below interesting, I did.
http://clubsearay.com/archive/index.php/t-45887.html
lakematdude is offline
Old 02-22-2014 | 07:32 AM
I am sure it WAS... P I T O T.. typo on my part.
Thanks... I check the sensor. I don't even know where it is or what it looks like, but I check around.
PARADOX is offline
Old 02-22-2014 | 09:27 AM
"PITOT CKT LO"
Pitot - speedometer
CKT LO - not installed , disconnected
babalu is offline
Old 02-22-2014 | 05:24 PM
Originally Posted by babalu
"PITOT CKT LO"
Pitot - speedometer
THanks, but I wonder why it should show up now. I removed the headers to check for leaks. I never had GPS speedo connected to the vessel view. I have a separate antenna for the GPS speedo. This code never showed up before. THe only code I ever head is trim.
PARADOX is offline
Old 02-25-2014 | 01:03 PM
Pitot sensor measures water pressure from speedometer pickup at sterndrive and transforms it to digital signal for vessel view or smartcraft instruments . It has no effect on engine run and it can be disabled through vessel view calibration.
babalu is offline
