labbed prop
Old 02-22-2014 | 11:47 AM
Default labbed prop
hey guys and gals,
Just installed cmi headers on my 496 ho. in a 28.8 sunsation. Before installing headers I was running 4 blade
26 pitch prop at 5150 rpms. would I benefit any by going to a lab finished prop and if so what pitch would you guys recommend.
thanks,
wayne
1stsunsation07 is offline
Old 02-22-2014 | 02:35 PM
I would try the prop you have first and see what rpm you get, the new exhaust may or may not change things enough to require a prop change.
flyinlow is offline
Old 02-22-2014 | 02:37 PM
Tinkerer's Avatar
You could probably go to a labbed 28.
Tinkerer is offline
Old 02-22-2014 | 08:25 PM
I run a labbed 28 on my Convincor with the 496 HO, but I also have a 1.65 drive. I would run that prop and get your slip numbers first. I thought redline on the 496 was 5050-5100 rpm? My prop should be back from BBlades Monday. It was labbed prior, had Brett tweak it a little more.
BIGBREW is offline
Old 02-23-2014 | 01:41 AM
Run it and see if you start hitting the rev limiter. If you do hit the limiter, talk to BBlades about either reworking your current prop or going to labbed 28.
Griff is offline
Old 02-27-2014 | 06:41 AM
doubt the exhaust will change much..
ezstriper is offline
Old 02-27-2014 | 08:45 AM
+1
BenPerfected is offline
