help! i need a picture of how the sea water pump mounts on a 500 efi
I bought the correct bracket, but I cannot figure out how it mounts on the block!!!
Maybe the dart big M block has holes on the wrong spot or I have something missing, but I cannot figure it out!!!
Thank you for any help.
Larry
If you have a picture you can post it here or email it to [email protected]
Larry
Thank you the picture, but it is different. My idler pulley is above the sea water pump. That is confirmed by my shop manual and it's picture of the belt routing. I do not have a pulley below the sea water pump like in your picture. I bolted the sea water pump to the upper of the two holes on the block, the lower one is really off. In the upper hole, the top hole on the bracket, I would assume is suppose to go on a stud screwed into the head, but it just doesn't line up?
See pictures. I am at a loss.
i sent you 2 pictures ?,yes it mounts to the cylinder head ....and the steel bracket that holds the idler pully mounts to the front of the block..
