93-35Lightning cabin seating removal >
Old 03-01-2014 | 01:55 PM
Default 93-35Lightning cabin seating removal
Want to remove cabin seating in my 93 Lightning, there are 3 sections one just lifts out and the other 2 larger section are screwed in somehow. My question is where are the screws. I looked between the cushion seam and could find none, called Fountain months ago and was told if I cannot find the screws pry the seating out with a crowbar. Not an option that I want to get into. Thanks for any assistance.
jackieboy is offline
Old 03-01-2014 | 05:26 PM
My 1990 had 3 stainless screws between the bottom cushion to hold it down and some brackets behind the back cushion to hold it in that were under the filler panel .
green lightning is offline
Old 03-01-2014 | 05:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Spread the seams apart as much as possible and look for holes in material and poke a phillips in there. You won't see screw heads. The screws will cut thru the material.
US1 Fountain is offline
Old 03-18-2014 | 05:11 PM
Thanks for the info, did what you suggested and had them out in about ten minutes. Used a razor blade to open up material to expose screws.
Old 03-18-2014 | 05:50 PM
Ginger or Mary Ann?
Great, but you didn't need to slice the hole open anymore. Just stick a phillips screwdriver into the hole and it'll locate into the screw head and just unscrew the screw back up thru the hole. Either way, you got it done
