Underwater LED placement on outboard Skater
What is the best placement for Underwater LEDs on outboard Skater. On the step above running surface or above on the transom. I'm thinking the lower placement beside the drain plug. Is there coring in this area?
[ATTACH=CONFIG]519593[/ATTACH]
Skate,here is where I put mine. Depends on the size\make you are using on whether they will fit on the lower step. Keep in mind the overhang from the step if mounted lower might block some of the lights. Zero Patience has green ones on his Skater that look nice with the colors of his boat. Mine are the Lumishore SMX150;s ,
Their lights are very bright. Offer many different surface mount models
ATTACH=CONFIG]519595[/ATTACH
ATTACH=CONFIG]519594[/ATTACH
I used 3 of these with 10% off use discount code TWORLD. They really light up the roost good when cruising at night. I mounted the outside ones pretty low and the middle is right below the waterline. http://www.bytortruck.com/product_in...-89124-p-93028
