Hydraulic fittings on outdrive >
Old 03-05-2014 | 08:40 PM
Default Hydraulic fittings on outdrive
I had to remove my two rams on my bravo 1 which means I took hydraulic line off of rams. When I reinstall the rams is there something I need to put on the threads of the 1/4" tube fittings? Thank u
236eagle is offline
Old 03-05-2014 | 09:09 PM
no,dont use anything on the threads but make sure you use a line wrench so you dont strip the hex.
mike tkach is offline
Old 03-05-2014 | 09:10 PM
Thank you!
236eagle is offline
Old 03-06-2014 | 08:40 AM
my pleasure.
Old 03-07-2014 | 07:52 PM
Mbam's Avatar
Offshoreonly Advertiser
I like moly coat or tef gel to make sure they come out easily next time.
Mbam is offline
