Mag 496 rear main seal tool?
I about to put my new seal in and it is a press fit. Does anybody know of an installer
To use or is there a secrete..I've done several seals on other engines but never these 8.1
And they are a press fit.
You might be able to put it in with a mallet if it is even and bottoms out correctly against the other piece.
There is a tool - it looks like a big circular cup.
Why do you need one....
If you have an oil leak, make sure ALL THE OIL PAN bolts are tight before you assume its the seal. 496's are notorious for the the oil pan bolts coming loose.
2 fresh rebuilds so I have new seals and I don't want them to leak. They are very tight and I don't want to egg shape or damage the seal by not evenly installing
Anybody have the part number on the circular cup shaped tool that fits
The tool I use is a nylon driver that is used for installing the Speedy Sleeve, the same size as a Gen 5 or 6 BBC. If you don not drive it on properly; you will have a issue. Make one O.D. 4.750 / I.D. 4.625, 1.000 depth.
