educate me on Sea Strainers >
Old 03-10-2014 | 08:28 AM
Default educate me on Sea Strainers
Hello all,
I have been looking at sea strainers for my Formula 252 with 454. Some of the strainers I have been looking at the Groco ARG Series, Sherwood (plastic not sure about this), then it seems it just to the higher end units Gil, and Teague 5 inch unit.
I am limited with space so of coarse the higher end units are smaller and seem to be a better choice. However, I have been seeing talk regarding pressure valves. Should I be concerned about this? My motor is stock so, I would guess my sea pump is not modified, but not sure if I should be concerned about a pressure switch.
Additionally, on a stock setup are the Sherwood and Groco units any good? I really dont want to break the bank on a sea strainer.
Any advice welcomed.
Priobe is offline
Old 03-10-2014 | 08:50 AM
I would stay away from anything plastic that's below the waterline. Of the units you mentioned, I would go with the Teague. You don't need a pressure valve.
Do you have freshwater flush on your boat? If not and you're installing a strainer, you should get one that has a flush inlet port. If you don't want to add the flush now, having the port will allow you to do it later and you can just install a plug in that port now.
HyFive578 is offline
Old 03-10-2014 | 10:29 AM
Yes I have a closed system with fresh water cooling.
Priobe is offline
Old 03-10-2014 | 10:31 AM
any particular model?
Priobe is offline
Old 03-10-2014 | 12:17 PM
What I was asking is.. do you have a freshwater flush setup to be able to run fresh water through the raw water cooling system. If you don't, then adding the sea strainer with the port for it is a good idea; much easier to hook up through the strainer.
In either case, if you add the strainer, you will also need to add a ball valve in-line between the strainer and the intake hose coming from your drive and you said space was tight, so keep that in mind too.
Old 03-10-2014 | 12:24 PM
Oh yes, I have a flush its a Perko in line flush system, ( harden plastic)
Here is a link to a pic http://www.westmarine.com/oil-change...1-1-4--6586085.
It looks strong but it has check valve for the fresh water flush and a check valve for cracking pressure on the inlet side to the sea pump.
It seems to work well, but I bought the boat with it. I am on the fence with this unit but have not seen and bad comments regarding it. SO maybe I should change this system out and use a manual valve as you are suggesting.
Your thoughts?
Priobe is offline
Old 03-10-2014 | 09:48 PM
Your thoughts?
You will get differing opinions on the perko flush unit. Some people swear by them and I know two people who have had them crack. Personally, I wouldn't want anything plastic below the waterline. If you develop a crack in the fitting end and it gives way while the boat is in the water, that's gonna be ugly.. Just my personal opinion.
Old 03-10-2014 | 09:53 PM
I have the original Groco SA series strainers that came with my Fountain in 1990. Still working fine, and fully serviceable. Not very blingy, but they work
MILD THUNDER is offline
Old 03-14-2014 | 11:38 AM
I wouldn't bother if your getting the sea water thru the drive but, If you have a transom or hull mounted pickup I'd consider a pressure relief, the psi spikes more as the boat airs out and comes back into the water. I have a closed cooling HO with a Gil strainer and a transom mounted pickup, when it spikes somewhere over 30psi it'll throw an alarm. I picked up my Gil strainer used for cheap and its mounted above the waterline
JerseyOutlaw is offline
