Need cam help! >
Need cam help!
Need cam help!
Old 03-10-2014 | 02:42 PM
VP of the tickfaw200
Default Need cam help!
Have gen 4 tall deck 540, proformance alum heads, dart intake the came is unclear to me as being good or not for marine use. Have trs set up with headers and dry exhaust.
[ATTACH=CONFIG]520057[/ATTACH]
Attached Thumbnails Need cam help!-ad13ee95-a02a-4b4b-a9bb-ef797143159e_zps4skvrym9.jpg
caseyh is offline
Old 03-10-2014 | 02:55 PM
johnnyboatman's Avatar
Just went thru this call bob mandera at MARINE KINETICS? it will save you alot of headaches.
johnnyboatman is offline
Old 03-10-2014 | 02:57 PM
What heads? That will make quite the difference
Unlimited jd is offline
Old 03-10-2014 | 03:13 PM
RHS from what I can tell. they are nothing special. That's also the cam that's in the motors now.
caseyh is offline
Old 03-10-2014 | 03:33 PM
Seems like an awfully lot of cam for a pleasure N/A 540 Marine. Just my opinion, but,
too much duration.
Intake valve closes too late
LSA too tight.
Is this a 10.5:1 engine that will turn 6500, or a 9:1 engine that might see 5500-6000?
MILD THUNDER is offline
Old 03-10-2014 | 04:19 PM
It's pro comp heads not RSH...
Not. Sure the. 10::5:1 From the info I have when I bought the boat
caseyh is offline
Old 03-10-2014 | 04:30 PM
SB
You sure they are not Pro Action ? RHS bought Pro Action. RHS and Pro Action made cast iron heads too.
ProComp is/was a fraudelent company. They make alot of crap. Some people like them....but I think that's there wallet talking. ProComp , in regards to heads, only makes them in aluminum.
BTW: I'm always nervous of others peoples used motors as they sit, but more so with cheap schit. My opinion.
SB is offline
Old 03-10-2014 | 04:37 PM
That's a whole lot of cam!! Pretty much a waste of Torque/HP in the power band that one would traditionally run a non-race marine motor in. JMO.
abones is offline
Old 03-10-2014 | 07:54 PM
It's pro comp heads for sure and that's the cam in the motors. So that cam coming out for sure. Thought it was big but wasn't sure.
caseyh is offline
Old 03-10-2014 | 08:26 PM
Wobble's Avatar
SORE MEMBER
Bob Madera with Marine Kinetics
Thinking on this subject, has anyone heard from Harold Brookshire (Ultradyne cams)
Last I heard he was recovering from a heart attack in 2012
Wobble is offline
