changing port engine starter 322 >
Old 03-11-2014 | 06:20 PM
Default changing port engine starter 322
so my 3 year old mercruiser starter has decided to give me troubles whats the best way to swap it? pull the engine? or pull the exhaust from both engines and hang upside down? the motors are magnums so i can lay on them. im really not looking forward to doing this......
thanks
neil
Yoda_Man is offline
Old 03-11-2014 | 06:53 PM
Are you positive it's the starter and not the slave solenoid
motor is offline
Old 03-12-2014 | 07:14 AM
+1. I also "thought" my starter was bad a couple years ago. I started to pull it, but once standing on head I noticed the ground cable going to the block had came loose! I cleaned up the cable ends, put some dielectric grease on them and tightened them up. Starter never sounded so healthy.
Good way to test it make your oven heavy duty (4 or 2 agw min) jumper cable for the negative. Jump between the battery and the block and see if it changes anything.
92nsx is offline
Old 03-12-2014 | 08:01 AM
obnoxus's Avatar
Charter Member #1171
if its not the solenoid,,,,,,,Pull the exhaust,,,,it will give you enough room
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-12-2014 | 02:11 PM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
+1
$25 and 10 minutes and you may be back in business.
Baja_342 is offline
Old 03-12-2014 | 02:44 PM
Isnt the solenoid on the starter?? Sounds like the same pain in the ass to me.....I'm already questing my decision going to twins...
kennyo is offline
Old 03-12-2014 | 06:53 PM
+1.....Same thing happened to mine on the starboard motor 2 years ago. I didn't do it (I have short arms LOL), but we did pull the exhaust and got it changed out in the boat.
rumrunner29 is offline
Old 03-12-2014 | 08:35 PM
the starter in there spins but doesn't engage. after a few tries it will engage and turn it over with little effort. I don't want it to wreck my short season
Yoda_Man is offline
Old 03-13-2014 | 07:12 AM
I don't want to give bad advice, but still sounds like a voltage problem / cranking amps to me..
92nsx is offline
Old 03-13-2014 | 07:14 AM
Not the slave. It's on top of the motor. Symptom would be a click, nothing happens.
Baja_342 is offline
