Need bmw mechanic
Old 03-12-2014 | 12:13 PM
JIMKID Motorsports's Avatar
Default Need bmw mechanic
any one on here a beemer mechanic let me know thanks
JIMKID Motorsports is offline
Old 03-12-2014 | 04:55 PM
i worked for bmw for 2 yrs,,i might be able to help you out with what ever you need..i mainly worked on the 7 series cars..the dealer i worked for had specialty mechanice working on certain series cars..
FIXX is offline
Old 03-12-2014 | 05:01 PM
Im a little far from you, but any advice i can give pm me. I own a shop and half my customers have BMW and Mercedes. happy to help
carrera1 is offline
Old 03-12-2014 | 05:27 PM
What is it you need done?
TURBO JET is offline
Old 03-12-2014 | 05:55 PM
Happy to help if I can... work on them all the time.
RT930turbo is offline
Old 03-12-2014 | 07:57 PM
Bad Ass TA WS6's Avatar
What do you need? Always game to play internet Diag. Been working on them for 10 years
Bad Ass TA WS6 is offline
Old 03-13-2014 | 07:14 AM
moparjet's Avatar
13 years at bmw tech at dealer. let me know if i can help
moparjet is offline
Old 03-13-2014 | 12:11 PM
I did a vc gasket and did not cycle the key before starting runs rough went back and reset the valtronic valve manually still running rough put new plugs in also thanks inadvance guys
Old 03-17-2014 | 02:23 AM
Did you manually set min lift on the valvetronic motor on removal? No faults/Check engine light? Theres a valvetronic gear stop that is mounted internally in the head that can snap if the motor is taken out when the spring tension snaps the valvetronic gear to min lift.
I've only ever seen that once our twice though. I'd bet the flange of the valvetronic motor may be bent if this method is used also though, which will cause a big unmetered air leak.
Old 03-17-2014 | 08:30 AM
What year car do you have and motor?
