Remote oil filter
Anyone ever used this exact part or ordered from these guys
http://marineenginedepot.com/MP/Mari...-Kt-5.0L-5.7L/
Chris
Chris
I notice the kit is for 305 and 350 engines. Are you sure the cooler you have is not for the power steering. The small blocks I had in the past never had an oil cooler. I changed mine to a setup like you hae posted to change the filter. Never did run a oil cooler until I stepped up to big blocks and got smarter. Again that was 30 years ago
The remote oil kit does not necessitate an oil cooler.
Starting the motor, and running it does. You should have coolers on everything in the bilge that uses oil....
Power steering, engine and drive. By keeping oil cool, hard parts live longer.
Follow the lines, I bet both lead to the power steering pump. Mercrusier never put an ENGINE oil cooler on the 305 and V6s and inline engines. Adding the remote filter just makes it easier to change the filter with out filling the bilge with oil. M2C
