Considering a 272
I found a clean 1996 272 w/ just 350 hours on it. But is has the 7.4LS EFI.
I'm seeing that is only a 300hp at the prop.
I have an older force 235 w/ a 7.4 that is 330hp (not sure that is rated at prop or at engine). It will get close but not up to 60mph. 55 56 all day, 58 with right load.
Owner of the 272 says it does 60 gps. With the same or less HP, and a bigger boat, I have my concerns about it really doing 60. I'm afraid of getting an underpowered boat.
What else should I look for? Potential issues/ problems?
thoughts please. TIA.
Had a 95 272 with carb 454 base engine, 310hp. With a Mirage+ 23 it was 55-56 mph, touched 57 once. Built the engine with bolt-ons and cam, went to a tweaked Mirage+ 25 and was getting 61 mph with a couple 62s. 272s with 502 Mag run 62 ish mph stock if I recall. Hope this helps.
He's not tellling you the truth.. I have a 99 272 454 mag 385hp, labbed prop 22 pitch 4 blade that runs 60-62mph all day long... I have touched 64 one time perfect condtions...
Thanks for the clarification guys. Exactly what I was afraid of. I am sure not going to buy a boat that is slower than my old boat w/ a smaller cockpit area to boot. LOL.
I appreciate the first hand info. Exactly what I was hoping for.
