Rebuild 575 SCI's and add closed cooling system >
Old 03-22-2014 | 07:34 PM
Vinny P's Avatar
I hate the winter!!
Default Rebuild 575 SCI's and add closed cooling system
I am currently nearing completion of rebuilding a pair of 575 SCI's. These engines are used in salt water. I last rebuilt these engines 5 years ago. At that time, the water passages in the intake manifolds were nearly rotted through. I ordered new Weiand intakes. I had the new intakes ceramic coated hoping the coating would help the water passages from rotting out. As you can see from the first picture, although the coating may have helped, it didnt stop the inevitable. The passages rotted through again, sending salt water into the oil pan, eating up the bearings. Luckily, it was caught before they failed completely. Rather than replacing expensive intakes again. I choose to attempt to weld up the water passages and have the intakes flat milled. The next picture shows the repaired intakes. This will be the last time these engines will destroy expensive parts due to salt.
The only guaranteed salt solution is to install closed cooling on these engines. The problem... no kit exists.So, I decided to make up the kit myself. Due to the location of the blower snout, mounting the exchanger looked like the most difficult part. I ordered heat exchangers from Monitor Products. Got factory Mercury closed cooling t-stat housings from Bam. Then went to work with steel and my tig welder to fabricate a way to mount the heat exchanger. I had to drill and tap additional holes in the intake to mount the t-stat housing. I also had to use a spacer between the intake and t-stat housing to solve clearance issues. It took a long time to figure everything out, but the project seems to be working out well. I am currently waiting for more water hoses, so I have not completed running all of the hoses yet. This is what I have done so far. I am highly confident that this will work well keeping the engine temp in range, while putting an end to the rotting problems associated with salt water.
More pictures to come as I get further.
Attached Thumbnails Rebuild 575 SCI's and add closed cooling system-intake-port.jpg   Rebuild 575 SCI's and add closed cooling system-p7200013.jpg   Rebuild 575 SCI's and add closed cooling system-p3160462.jpg
Rebuild 575 SCI's and add closed cooling system-p3160466.jpg   Rebuild 575 SCI's and add closed cooling system-p3160467.jpg   Rebuild 575 SCI's and add closed cooling system-p3210471.jpg
Rebuild 575 SCI's and add closed cooling system-p3210472.jpg   Rebuild 575 SCI's and add closed cooling system-p3210473.jpg   Rebuild 575 SCI's and add closed cooling system-p3210474.jpg
Vinny P is offline
Old 03-22-2014 | 07:57 PM
Very impressive -
Wes Burmark is offline
Old 03-22-2014 | 08:02 PM
Mr Gadgets's Avatar
Charter Member #601
Nice Work Vinny!!
Mr Gadgets is offline
Old 03-22-2014 | 08:27 PM
Vinny P's Avatar
I hate the winter!!
I found a few more pics.
Attached Thumbnails Rebuild 575 SCI's and add closed cooling system-p3220480.jpg   Rebuild 575 SCI's and add closed cooling system-p3220481.jpg   Rebuild 575 SCI's and add closed cooling system-p3220482.jpg
Vinny P is offline
Old 03-22-2014 | 11:04 PM
Great job Vinny, now I can't wait to get them in the boat a run them...... Summer can't come soon enough !!!
Here's Johnny is offline
Old 03-23-2014 | 08:49 AM
Nice work...
HyFive578 is offline
Old 03-23-2014 | 11:59 AM
Very nice! if the stock thermo housings are still in good shape, hang on to them...they are gold. Expensive, and hard to find. I believe they used them on the 850sci as well.
4bus is offline
Old 03-23-2014 | 12:28 PM
nice work,imo closed cooling is the only way to go in a salt water world.
mike tkach is offline
Old 03-23-2014 | 03:31 PM
nice setup. be prepared for a buncha people wanting you to do up a set or two for them. personally i can't see even a peanut 330 with salt water cooling.
dereknkathy is offline
Old 03-23-2014 | 04:50 PM
Vinny P's Avatar
I hate the winter!!
Yes, the original t-stat housings are in good shape. Maybe Johnny would let them go if someone needed them.
I cant wait to fire these engines up. It should be soon.
Vinny P is offline
