exhaust tips with big turndown >
Old 03-24-2014 | 05:41 AM
Default exhaust tips with big turndown
i have seen this setup on i think a big formula cruiser. thru hull exits above waterline and tip turns down so exit is underwater when not on plane. where would i find something like this? and what are the drawbacks?
dereknkathy is offline
Old 03-24-2014 | 05:48 AM
Drawbacks: No cool idle sound, especially when next to a sea wall. You can't make everyone jump when you fire the engine(s). Q&Q gives you an option but I only use it at idle when I need to. Like around cops.
thirdchildhood is offline
Old 03-24-2014 | 06:20 AM
I think this thread will help.
http://www.offshoreonly.com/forums/g...-too-loud.html
1BIGJIM is offline
Old 03-24-2014 | 07:14 AM
http://gibsonmarine.com/turndowns.html
Gibson turndowns
92nsx is offline
Old 03-24-2014 | 10:01 AM
What about the theory of condensation up inside the pipe,s or or drilling a hole in the high side of the pipe so to let it breath when dead in the water ???
575cat is offline
Old 03-24-2014 | 10:17 AM
The major drawback I see is when installed they look gayer than 2 dudes kissing in the back seat of a Prius
TooLateVTEC is offline
Old 03-24-2014 | 10:31 AM
VoodooRob's Avatar
^^^^^^ That there Clarke is funny ^^^^^
VoodooRob is offline
Old 03-24-2014 | 10:54 AM
All I keep thinking is moisture galore on turn downs.... How could they NOT suck for moisture issues?
How are the Gatling Gun inserts? They look cool and hypothetically seem like they would work.
Keith Atlanta is offline
Old 03-24-2014 | 04:39 PM
how could moisture be any worse than thru prop? and it will be under molded swim platform so no gayness will be evident...
Old 03-24-2014 | 04:54 PM
Yep. Keep it in the bedroom or under the swim platform . Big cam and blown engines don't use through prop exhaust.
