Is your stereo wired through your key/ >
Old 03-30-2014 | 06:15 PM
Default Is your stereo wired through your key/
How are your stereos wired? Currently mine is on as long as the battery switch is on and I don't like that, but I'm not sure what to do about it.
Thinking about adding a switch on the dash for the radio, what are yall's thoughts?
Cole2534 is offline
Old 03-30-2014 | 06:18 PM
it should have its own switch
pstorti is offline
Old 03-30-2014 | 06:23 PM
Payton's Avatar
Charter Member #927
Mine has it's own switch and breaker.
Payton is offline
Old 03-30-2014 | 06:27 PM
That's what I was planning to use, a switched breaker.
Cole2534 is offline
Mine is wired live, fused. Hitting the off button is off but "stand by" holding the off button turns the radio all the way off.
Switch is too complicated if someone trips it (they always do) you have to turn it back on, set the volume, and sometimes restart the playlist
4bus is offline
Old 03-30-2014 | 06:32 PM
4bus, I agree, fat-fingered bastages.
I'm thinking set it up so that the radio is on when the key on, or when the switch is flipped.
Cole2534 is offline
Old 03-30-2014 | 06:51 PM
Im setting my rigging up so that when the battery switch is on, the fuse box is energized. The stereo will be wired to the fusebox.
phragle is offline
Old 03-30-2014 | 07:09 PM
Have its own switch but dont use the ignition key or you will rack up hours without running...
moderatedUser23082018 is offline
Old 03-30-2014 | 07:16 PM
Mine goes full on as soon as the battery is switched on. I have to hurry to shut it off once the switch is on. No likey. I'm going to wire it so the always hot(memory) is fused to battery and the radio/cd is wired through the battery breaker radio switch. Once the main is on, it lights the breakers on the main panel.
ham_r_down01 is offline
Old 03-30-2014 | 08:46 PM
Wobble's Avatar
SORE MEMBER
+1 do not want to overheat your ignition just to play Justin Bieber
Wobble is offline
