Miami Vice 38KV colors/paint codes NEEDED ASAP! >
Old 03-31-2014 | 03:45 PM
Default Miami Vice 38KV colors/paint codes NEEDED ASAP!
My boat is down at Victory Marine for some partial resto work and we need the actual paint code numbers that Wellcraft painted the boats in 1987.
Does anyone have this info anymore? Wellcraft does not have them anymore and I want to be exact!
Anyone?????
JetJock is offline
Old 04-01-2014 | 09:55 PM
Can't you paint match it?
315duramax is offline
Old 04-06-2014 | 11:35 AM
want the correct numbers.....trying to do it right.
JetJock is offline
Old 04-06-2014 | 08:31 PM
hblair's Avatar
If you're just painting part of the boat, then the right way is getting a good painter to match the color. It would be good to have the original formula to start with, but that would a be a "start", then the painter would have to tint the color to get it closer. Now if you're painting the whole boat, and don't have the original color showing, that's different.
hblair is offline
Old 04-20-2014 | 07:55 PM
Here are Imron paint codes
http://www.campyonly.com/images/joebell/imron.pdf
Top stripes are black. Imron Paint code 4435.
Paint Color is Black Metalic
(Note, some of the "MIAMI VICE PAINT CODE" options had them as dark blue, but on the show they were black metalic)
Fade Stripe goes front to back:
Imron 44493 Dark Viloet to
Imron 7446 Blue Metalic to
Imron 45024 Green Metalic
All above brought to you courtesy of you 38KV Miami Vice fan page on Facebook.
JetJock is offline
Old 12-01-2018 | 12:02 AM
Wow, I needed these also... going to paint my panther Vice Theme.
PuTang is offline
Old 12-01-2018 | 09:11 PM
All you need to do is take the boat to any automotive paint store and they have a camera that takes a picture and a computer tells you the paint code. Almost any large body shop also has these cameras. Do it all the time in my shop. Jeff wurl
jwurl is offline
Old 12-05-2018 | 01:40 PM
I was looking for this as well. Does anyone have a price range on what this will cost to get painted? To have mine wrapped, I'm looking at $6k.
DashMatthys38 is offline
Old 05-15-2020 | 10:55 AM
hblair's Avatar
When I replied to this in '14, I didn't know 6 years later I'd be needing all these codes myself. Jetjock, did you get this off the facebook page? Did it come from the shop in new york that restored star1 years ago? This is what I plan to go with but want to do a little more research before I pull the trigger. Thanks.
hblair is offline
