Bravo 3 tilt limit switch >
Old 03-31-2014 | 05:51 PM
Default Bravo 3 tilt limit switch
I noticed if I turned the out drive all the way to the starboard side I can see the clamp where the tilt switch and tilt sender goes into the transom. Has anyone tried to remove the tilt switch without removing the drive through this access?
Priobe is offline
Old 04-01-2014 | 07:18 AM
Yes I do it with a 1/4 inch drive. When you put it back on tape the bolt to the socket so it stays in place.
1BIGJIM is offline
Old 04-01-2014 | 07:43 AM
Thanks....
It was funny I turned the drive and there is was starring at be :-) cool.
I will bypass the switch to make sure the Tilt switch is my problem.
How long does it take you to do? and can you do the gauge sender this way too?
Priobe is offline
