Fuel line from duel feed holley >
Old 03-31-2014 | 08:42 PM
Default Fuel line from duel feed holley
What is the best way to adapt the fuel line kit below for a dual feed holley to the stock mechanical fuel pump on a 454 mag (3/8 hard line). Is there an adapter fitting? It would have to be a JIC to 3/8" brake line type fitting. The local NAPA was not helpful. Thanks.
http://www.summitracing.com/parts/sum-220100/overview/
Mr Maine is offline
Old 04-01-2014 | 03:21 AM
An fittings have the same degree flare as brake lines or they make -AN compression fittings but I don't recommend doing that. You will need a flare tool -AN nuts and Ferrells for hard line.
Black Baja is offline
Old 04-01-2014 | 04:31 AM
vintage chromoly's Avatar
Actually, AN fittings have a 37 degree flare and a standard SAE flare is 45 degrees. There is a specific flare tool for each.
if you want to use AN stuff, take it all the way from the carb to the pump. Don't try to splice it together.
vintage chromoly is offline
Old 04-01-2014 | 06:13 AM
Your right don't know what I was thinking I have a completely different set for doing AN stuff.
Old 04-01-2014 | 06:21 AM
That's how I did it on the Mustang.
thirdchildhood is offline
Old 04-01-2014 | 09:03 AM
SB
The fuel line adapter (#11 in pic below) I believe is just 1/4" NPT going into the pump. Fuel line side, if i remember right, is 3/8" flare.
Easy enough to make something up. Hard line, AN Braided, AN Pushlock (my fav choice for low psi fuel), or etc.
If your Napa is like mine, they don't even know what a damn carburetor is. LOL.
SB is offline
Old 04-01-2014 | 09:25 AM
Thanks for the responses. Since we already have the an style duel feed with pressure gauge would like to use it.
SM, so I would take the flare fitting out of the pump and replace with a pipe to an style adapter. Then get a length of an hose with the correct ends. Wlso the length of hose would need to be the right length. If I had the parts in front of me I could make it work but I dont.
Just seems complicated to hook up a simple carb
Mr Maine is offline
Old 04-01-2014 | 09:42 AM
SB
Like everything else, only complicated when you do something for the first time and have no local parts help. So, when you are done, it will be easy the next time...if there is ever a next time.
As a tech help, typically getting a 90* pipe to AN coming out of your fuel pump is a help...vs a straight fitting. This way your line goes up vs out and then have to bend to go up.
What size AN and if male or female from your Carb duel feed line set-up ?
SB is offline
Old 04-01-2014 | 10:23 AM
[ATTACH=CONFIG]521246[/ATTACH]
What you need is a 90 degree AN adapter at the pump. Your pump is prob either 3/8 NPT, or 1/4NPT. Plus a 90 -8 hose end, and hose
http://www.summitracing.com/parts/sum-220850/overview/
or 1/4 NPT
http://www.summitracing.com/parts/ea...7erl/overview/
Then for the connector at the fuel log
http://www.summitracing.com/parts/sum-220887/overview/
and the hose
http://www.summitracing.com/parts/sum-230803/overview/
MILD THUNDER is offline
Old 04-01-2014 | 10:40 AM
SB, MILD thanks for the info that is very helpful. Yes we need a 90 at the pump outlet as it goes straight toward the engine mount. One more question, is a tool needed to install end fittings on the hose?
Thanks again
Mr Maine is offline
