Wheel Bearing Size???
remove 1 of the other wheels. Sounds like a good time to go thru all 6
*Timken
http://www.timken.com/en-us/Pages/Home.aspx
Made in the USA and 1000% better than the Chinese bearings that come in just about everything, and usually sold retail.
18K rated, so 6K axles?.
Last time I checked, Timken bearings, which are the best, were outrageous.
If a 6K axle with 1 3/4" x 1 1/4" tapered spindle, try this. Inner bearing (25580) and outer bearing (67048), You should be able to buy a complete kit (bearings, races, cotter pin, nut and washer) for $15-$20. If you have a Northern Tool or any trailer repair shop close, they should have what you need.
1) American made
2) Better steel
3) 1/3 more bearings +/-.
OSO member Doc Holiday did all of the comparisons here on OSO many years ago. I learned a lot; and I go out of my way to obtain Timken bearings. Their axle seals are also far superior. I've been towing for close to 20 years, and I've never had a bearing failure. I must be doing something right (as I knock on wood).
I'll gladly pay the extra money vs. sitting on the side of road, putting me, my family/passengers, my rig, at risk; and getting dirty as a ditch digger while I really want to be either where I'm going; or out on the water.
