Wiring engine pictures
Old 04-06-2014 | 10:24 AM
Default Wiring engine pictures
I can wire stuff all day but I hard time making it look neat .. I`d love some pics of the back of engine please to give me ideas.
Instead of the usual corrugated wire looms I was thinking braided looms maybe?? I like different.
http://www.grainger.com/product/TECH...LL3?s_pp=false
ICDEDPPL is offline
Old 04-06-2014 | 04:42 PM
That's the stuff I use on everything...boat....car....truck....motorcycle
A few nice things about it.....
Pinch a few inches back to get her and you can see the wires inside....great for troubleshooting.
When running a branch circuit, you can pull the wire throuh the braid and put a smaller diameter braid on that branch circuit, exactly where you need it.....
commandersander is offline
Old 04-06-2014 | 04:47 PM
vintage chromoly's Avatar
I was just looking at the same stuff in my grainger catalog the other day. I usually use the spiral wire loom and I generally like it but I may buy a roll of the stuff you linked and give it a shot.
vintage chromoly is offline
Old 04-06-2014 | 05:01 PM
Mcmaster has a pretty good selection too. http://www.mcmaster.com/#standard-ca...eeving/=rf9bpd
Cole2534 is offline
Old 04-06-2014 | 07:16 PM
Well I got impatient I picked up something similiar from a local Napa. This stuff is tough... kinda hard to cut actually.
http://www.napaonline.com/Catalog/Ca...103_0063685816
It aint no Eddie Young job thats for sure but for my first time wiring up a marine motor, I`m happy how it came out
ICDEDPPL is offline
Old 04-06-2014 | 07:25 PM
Looks great Dan!
Why dont you tell everyone about all your fancy sensors.....High water temp switch(light on at 180), high oil temp switch(light on at 275), high trans temp switch, low fuel pressure switch(light on at 4psi),
MILD THUNDER is offline
Old 04-06-2014 | 07:42 PM
Thats was a great idea Joseph!
....those above along with low fuel pressure , low water pressure..etc, all will be wired to some bright ass warning lights with a custom panel. Less worry about always checking the gauges.
I wired all those warning sensors to one connector for easy hook up:
ICDEDPPL is offline
Old 04-06-2014 | 07:46 PM
Awesome, will make for a nice plug and play setup on that. Good stuff
Old 04-06-2014 | 07:56 PM
Question
The negative to the Alternator .. can I ground that to the block or go all the way to the battery negative on the block?
ICDEDPPL is offline
Old 04-06-2014 | 08:37 PM
You can ground it to the block as long as you have a clean spot that free of paint, rust, etc.
The wiring is looking good brother.
Here are a few of mine.
We make the electronics plates in house out of aluminum, carbon fiber, whatever.. That is the key to having neat wiring. You must have a good place that is centrally located to mount everything. I also find it helpful to sketch out a schematic of all of the wiring first, so that I don't forget everything. There is nothing worse than strapping everything up nice and neat and realizing that you forgot a wire.
Attached Thumbnails Wiring engine pictures-dsc03083.jpg   Wiring engine pictures-dsc01663-large-.jpg   Wiring engine pictures-dsc02814-large-.jpg
Wiring engine pictures-dsc03125-large-.jpg   Wiring engine pictures-seeleys-fountain-110-.jpg   Wiring engine pictures-dsc02888-large-.jpg
Young Performance is offline
