What fuel would your run >
Old 04-08-2014 | 08:15 AM
hangem out 2dry's Avatar
Default What fuel would your run
If you had to make a choice what fuel would you run on a boost application 540 procharger with 5 to 7 lb of boost. 91 octane no ethanol or 93 with ethanol.
hangem out 2dry is offline
Old 04-08-2014 | 08:31 AM
as much as i hate ethanol i hate detonation worse,i would use the 93.
mike tkach is offline
Old 04-08-2014 | 08:57 AM
inspector747's Avatar
Do they not offer 93 without Ethanol where you live?
inspector747 is offline
Old 04-08-2014 | 09:29 AM
no they sure dont
Old 04-08-2014 | 09:35 AM
Surprisingly I have never had an ethanol related problem yet. Have a few hot rods not driven often and of course the boat. Try to at least start up fairly often and always run stabil thru everything before winter storage so it enters carbs ect...I run the tanks down to about 1/4 before winter... Been running 93 w/ 10%ethanol (Our only choice in 93. Try to avoid 91)
Eliminated572 is offline
Old 04-08-2014 | 10:12 AM
no they sure dont
Only reason I asked was there a few stations in LA that have 93 Ethanol free. I'm sure there is a link on this site somewhere but here it is just in case
http://pure-gas.org/
Old 04-08-2014 | 10:29 AM
hullofjustis's Avatar
I think i would run non ethanol and use octane booster or 5 gallons or so of race fuel,. I despize ethanol fuel.
Ior i would put a exhaust temp sensor in my manifolds.
hullofjustis is offline
Old 04-08-2014 | 10:51 AM
inner cooler? Steel heads?
skydog is offline
Old 04-08-2014 | 11:18 AM
inner cooler aluminum heads
Old 04-08-2014 | 11:43 AM
Nice set-up, 93 would be my pick too. Whats your CR? Does it have a big cam? Or average hydraulic?
skydog is offline
