props size - help please
Hello;
We have boat with next datas:
- weight 12.000 lb
- lenght 30 ft
- 2x diesel 275 hp each and 3.300 rpm wot
- Arneson 6" drives
- drop down with 1,2 reduction
What kind of props with what dimensions to put on shafts for best results?
bye
Saso
- weight 12.000 lb
- lenght 30 ft
- Arneson 6" drives
bye
Saso
20 pitch prop will take you to 45 mph at 3300 with 15% slip. Diameter is dependent. Start big (16.5"-17" ???) you can always cut it down. You may need a custom propeller to find this size.
HP to weight ratio suggests you should be able to do this pitch. Of course this is without knowing the boats configuration.
Brett
Brett
[email protected]
[email protected]
