Go Back  Offshoreonly.com > Multi Media Gallery > Members On-line Video Section!!
sick engine room explosion- HD Miss GEICO onboard >
Old 04-14-2014 | 11:20 AM
MissGeicoRacing's Avatar
Racer
Exclamation sick engine room explosion- HD Miss GEICO onboard
If you are wondering what happened. Take a moment to watch this Go Pro vid
http://youtu.be/mb8IoTOrh9M
www.facebook.com/missgeico
Note: The failed driveshaft U-Joint was not a Mercury Racing supplied part
MissGeicoRacing is offline
Old 04-14-2014 | 11:24 AM
Liquid Fix's Avatar
Wicked!!
Liquid Fix is offline
Old 04-14-2014 | 11:27 AM
TYPHOON's Avatar
What let lose the U joint?
TYPHOON is offline
Old 04-14-2014 | 11:28 AM
obnoxus's Avatar
Charter Member #1171
Nothing lasts !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-14-2014 | 11:30 AM
obnoxus's Avatar
I thought it was the rear joint from the video at first,,,,, but if you look at the end of the video,,,, the yoke is still flopping around on the U joint
obnoxus is offline
Old 04-14-2014 | 12:56 PM
jayboat's Avatar
I wondered what happened to ya... hope it's an easy fix.
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
Old 04-14-2014 | 01:18 PM
I don't think its the yoke, or u-joints, I think the motor locked up, but the props were still spinning incredibly fast, causing the drive shaft to blow out of the housing...
stlliberator is offline
Old 04-14-2014 | 01:21 PM
Racer
The rear u joint failed. as you can see it decimated the shroud and wiped out a 2 inch thick carbon stringer not to mention the tranny, drive plate bell housing etc
. I think the HP numbers everyone is used to seeing nowadays have desensitized us to the amazing forces at work in our boats this vid clearly depicts the violence when it is unleashed somewhere other than the prop. Stray and the boys will have her fixed and turned around for Biloxi in a week and a half...now thats amazing stuff
Old 04-14-2014 | 01:22 PM
How much horsepower is going through that single shaft? Looks like that is the current weakest link in the chain?
tpabayflyer is offline
Old 04-14-2014 | 01:26 PM
Gladhe8er's Avatar
Nasty!
Gladhe8er is offline
