Low of 27 Tonight, Should I do anything??? >
Old 04-15-2014 | 10:10 AM
Default Low of 27 Tonight, Should I do anything???
So the low is suppose to be 27 tonight, and it will be 32 or under for about 6 hours, should I be worried about the boat at all? I am thinking no, but wanted to see what you guys think? And if I should do anything?
ealesh33 is offline
Old 04-15-2014 | 10:17 AM
LV's Avatar
LV
Throw a light in the bilge, and you will be fine.
LV is offline
Old 04-15-2014 | 10:19 AM
inspector747's Avatar
Make sure the out drive is down as well (If not already)
inspector747 is offline
Old 04-15-2014 | 11:16 AM
yup, incandescent light bulb in the bilge will provide enough heat.
MonkeySea2 is offline
Old 04-15-2014 | 11:22 AM
So you guys are saying I need to get down to the marina and put a heater or light bulb in there cause there is a risk of damaging something?
ealesh33 is offline
Old 04-15-2014 | 11:29 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
JUST discussed.
Read the posts on this thread:
http://www.offshoreonly.com/forums/g...ted-issue.html
Sydwayz is offline
lastcall02's Avatar
You should be fine. I've always been told that it takes several back to back days of below freezing temperatures to cause any damage.
lastcall02 is offline
Old 04-15-2014 | 11:48 AM
Originally Posted by Sydwayz
JUST discussed.
Thanks, but why would have I looked in that thread to answer this question? When you search, which is something I do often and go digging through many threads before I find a remotely close response to answer whatever question I may have at the time. Sometimes man I just don't have time to go digging into threads to find an answer. I appreciate you directing me toward that thread, and it looks like it is a mixed bag of responses on whether it will be just fine as is, or go and put a heater in the bilge and lower the drive. The reason I am asking is because it isn't convienant at all to go to my marina. It is 30min away from my house, I work till 5, would have to cancel plans that are made, and it is a monsoon out there today. Now I will 100% do what is needed to be done if there is a risk that something can get damaged, but that is what I am trying to figure out. You think something will get damaged? Or if it was your boat and you were in the same situation I am in, what would you do?
ealesh33 is offline
Old 04-15-2014 | 12:03 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I wasn't chastising, just guiding you too a very recent similar convo so you could see some relevant opinions. A search would not have found that.
IF it was my boat, and knowing that I have the tiny/thin brass tubes in the very expensive heat exchangers...
...I'd make arrangements to address.
Sydwayz is offline
Old 04-15-2014 | 12:04 PM
I believe 3 people have told you to go put a light bulb and 1 said you should be fine. It's your call but you do have a 3 to 1. Call the marina and have them do it or else if something gets damaged you can't say noone told you but then again im sure you wouldn't say something got damaged. I don't have that problem as i live in Miami. ... good luck
SkaterMike82 is offline
