Torque # on transom assembly >
Old 04-15-2014 | 06:23 PM
bigboat28's Avatar
Default Torque # on transom assembly
How many lbs of torque do you tighten the transom assembly nuts to on the inner transom assembly?
bigboat28 is offline
Old 04-15-2014 | 08:02 PM
Good question.... If its a wood transom 20 ft lbs. You can come back 1/2 hr later and it'll take another full turn to get that 20 ft lbs again. Since the wood squishes over time you can keep doing it over and over.... But the 1st 20 will be fine ( for Bravos & alphas)
fastdonzi is offline
Old 04-16-2014 | 12:11 PM
bigboat28's Avatar
It is a mercruiser speedmaster III. I torqued the 8 nuts to 30lbs, hope it is correct.
Old 04-16-2014 | 12:30 PM
Bravo spec is 35 iirc. I just did mine to where it felt good. Maybe 45 or so
Unlimited jd is offline
Old 04-16-2014 | 12:44 PM
TeamSaris's Avatar
Driver-441
Racer
Stick with the Merc spec, they crack fairly easily when over tightened.
TeamSaris is offline
Old 04-16-2014 | 12:52 PM
bigboat28's Avatar
So is spec for speedmasters 35lbs? I googled it and cant find anything other than one link talked about 25lbs.
Old 04-16-2014 | 06:45 PM
Glad to see your using the google search engine I told you about
s022mag is offline
Old 04-17-2014 | 08:43 AM
Roger 1's Avatar
The Mercury manual states...."Tighten elastic stop nuts evenly by hand and torque to 50 lb. ft.".
Roger 1 is offline
Old 04-17-2014 | 05:52 PM
spazboz's Avatar
Yep. Just opened my 1995 manual and it also states 50lbs for III's and V's.
spazboz is offline
Old 04-17-2014 | 08:03 PM
bigboat28's Avatar
Thank you
