Adding Bunks???
Old 04-30-2014 | 09:01 AM
Default Adding Bunks???
I have a Fastload now with 2 large beams notched out for the steps and up front some PVC tubing that I guess is suppose to help guide the boat on shaped like a V. In between the tubing is just a plastic pad that the boat rest on. I figure most of the weight is on the rear but when trailering and loading that plastic BS just doesn't sit well with me. Not to mention with steep ramps. I was gonna add 2 2X6's prob 8 feet long, it's 80" from cross beam to the cross beam that the tubing sits on. I think I have figured out what I need hardware wise just was curious if any one has some pics of them adding bunks to the front.
If I get a chance I'll add some pics of what I got on the trailer now when I get home.
s022mag is offline
Old 04-30-2014 | 09:42 AM
Also was thinking of adding this kind of bow stop and getting rid of the traditional roller.
[ATTACH=CONFIG]522811[/ATTACH]
s022mag is offline
Old 04-30-2014 | 12:17 PM
badmonkey's Avatar
where did you find this bow stop? I am so tired of the roller peeling paint off the bow.
badmonkey is offline
Old 04-30-2014 | 01:10 PM
http://rockettrailers.com/PartsBook/...erBowStops.htm
This is where I found that one. I've seen fountains have them and even black thunders.
s022mag is offline
Old 04-30-2014 | 01:18 PM
Found this old thread too.
Bow Stop
s022mag is offline
Old 04-30-2014 | 01:44 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
http://www.championtrailers.com/
Source your parts here. Very easy to work with.
They have everything from cross members with V-notches to bunk supports.
Your boat will load a LOT better with them as well.
IF you add a pair of 2x6 down the keel of the boat in between the big bunks, it will load/center even better than with just the V-bunks added up front.
Sydwayz is offline
Old 04-30-2014 | 02:04 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Sydwayz is offline
Old 04-30-2014 | 02:27 PM
Thanks for the advice, never thought about that. I'm gonna start with front then add to the rear. The only other way would be poles and I don't want to f with those.
s022mag is offline
