Go Back  Offshoreonly.com > Technical > Electronics
SMartcraft with 525EFI >
Old 05-06-2014 | 12:39 PM
Default SMartcraft with 525EFI
my 525EFI does not have a plug connection for the fuel level sender. So I canīt see the fuel level. Does anybody know, if it is possible to connect the fuel level sender to the junctionbox?
Searay220 is offline
Old 05-08-2014 | 06:40 AM
Mbam's Avatar
Offshoreonly Advertiser
There is a tank harness that connects to the engine. I can look up the PN later. Not expensive if i remember correctly
Mbam is offline
Old 05-08-2014 | 08:25 AM
I have the tank harness, but no plug connection at the engine :-(
Old 05-08-2014 | 09:17 AM
Mbam's Avatar
That is strange. Sometimes it is buried in the back & hard to find. Are there any open connectors at all? Do you have the serial number?
Mbam is offline
Old 05-08-2014 | 11:00 AM
the # is 0M905419
I think I have searched at every possible places - did not fin anything. The steering connector is free...
Old 05-08-2014 | 11:18 AM
Mbam's Avatar
Here is the transom conection from the 525 install manual. Does your's look like this?
File Type: pdf
Mbam is offline
Old 05-09-2014 | 10:46 AM
No, I do not have this cable. Mine is only 10 Pin, I donīt have Fuel Level I, Fuel Level II, Tab I and Tab II, Trim pump, Trim switch and Shift position.
send your e-mail adress and I can send you pics of the connector.
Is it possible to put an Y connector at the blue Smartcraft cable and connect it with an adapter to the fuel level harness?
Old 05-09-2014 | 11:39 AM
Mbam's Avatar
Email sent
Unfortunately a junciton/y connector won't work. The fuel sender is analog and the ECM is what converts that to the digital signal that becomes part of the data on the can (smartcraft) cable.
Mbam is offline
Old 05-10-2014 | 05:59 AM
but it worked at my 496Ho I donīt understand why?
Old 05-10-2014 | 08:21 AM
Mbam's Avatar
Here is a page from an older 525 service manual. It does look different than the later install manual. Looks like they changed it along the way.
So it looks like there should be some bullet connectors floating around on a “whip” a few inches from the main connector. Anything like that?
File Type: pdf
Mbam is offline
