Oil consumption >
Oil consumption
Oil consumption
Old 08-19-2002 | 10:39 AM
sheikman1
Default Oil consumption
Just need an answer from somebody who is experiencing a similar problem...
Is it normal for a Gen V 540 motor to burn oil ???
I was told because I have forged pistons tolerances were set up with more clearance and thats why I burn some oil. Motor now has 15 hours on it. Would too large of jets in the carb contribute to this problem???
I am running 84 primary, with 94 on secondary.
Carb is a 800cfm holley with mechanical secondarys
Sheikman
Old 08-19-2002 | 10:49 AM
Shooter's Avatar
Charter Member #300
it's common,
My blow 454 magnum does it, so do the twin 502 MPI magnums also. Usually when you are throttle happy.
Shooter is offline
Old 08-19-2002 | 11:17 AM
Official OSO boat whore
The factory 502's are using oil. The reason is that the motor is a stock GM piece and they are set up with low tension oil control rings. The problem is that your motor is not factory, so it shouldn't be using much oil. And no, the carb jetting wouldn't affect the oil consumption...unless something was really wacked and damage resulted...
Cord is offline
Old 08-19-2002 | 12:43 PM
My 1997 merc 454 mag burned a qt every 4-6 hrs. Factory said it was normal. I put a procharger on it and it stopped!
Pure Energy is offline
Old 08-19-2002 | 01:01 PM
Tantrum's Avatar
What is the recommended gap on a supercharged 454 w/ forged pistons ?
Tantrum is offline
Old 08-19-2002 | 01:24 PM
1/8"
Cord is offline
offthefront
18
03-24-2005 08:33 PM
Bostonsoxfan
4
06-28-2004 11:56 PM
chriscraft240
2
07-29-2003 11:51 AM
HARRISONMIRAGE
4
06-11-2002 06:50 AM
