Where can I get exhaust block off plate >
Old 05-19-2014 | 02:00 PM
Default Where can I get exhaust block off plate
My boat has captains choice and won't work with my headers so I was going to take the y pipe off. Where can I get a block off plate for it for bravo 1 outdrive? If from marina does anyone have part #
blackta is offline
Old 05-19-2014 | 02:19 PM
Aqui-
http://www.keitheickert.com/p-13860-...lications.aspx
Cole2534 is offline
Old 05-19-2014 | 03:23 PM
Originally Posted by Cole2534
I have one used if you want it 20.00 shipped
COOPS is offline
Old 05-19-2014 | 04:23 PM
Expensive Date's Avatar
CP performance makes really nice ones were you can leave the Y pipe in. I have a used set $30.00 shipped cont. US
Expensive Date is offline
Old 05-19-2014 | 04:27 PM
Are you talking about the caps that go over the ends of the Y-pipe where the exhaust hooks up?
Budman II is offline
Old 05-19-2014 | 05:14 PM
I have the exact one listed
You have to pull the y-pipe to install it. It bolts to the inner transom plate to block the exhaust exit under water.
COOPS is offline
Old 05-19-2014 | 09:35 PM
[ATTACH=CONFIG]523602[/ATTACH] No these you use the rubber coupler, they go inside the coupler.
Attached Thumbnails Where can I get exhaust block off plate-img_20140323_141626_934.jpg
Old 05-20-2014 | 05:49 PM
engine has to come out for anything but expendate's setup. then just get 3 feet of hose cut in half to run where diverters were.
dereknkathy is offline
Old 05-20-2014 | 09:49 PM
I did the el cheapo redneck solution to the problem - similar to what Expensive Date has. Went to Lowes and got some rubber plugs in the plumbing department, installed them in the rubber boots with some Right Stuff to seal them up. Ran some stainless screws through them for insurance that they couldn't pop out. Ran two years like this without leaking a drop. Planning to put SC back on, so it was a temporary solution, but it worked fine.
