Baja Outlaw 36 - No voltage to the stereo >
Old 05-22-2014 | 03:08 PM
Default Baja Outlaw 36 - No voltage to the stereo
I have a 99 model Outlaw 36, with no power to the stereo. Is there a factory installed fuse, circuit breaker, rocker switch, or some other component that I'm overlooking? I've tried everything on the instrument panel, and I've checked everywhere I know to look. Has anyone else run into this? Thanks in advance for the help.
marc9889 is offline
Old 05-22-2014 | 04:01 PM
Yep. Probably. In addition to the fuse in the fuse box, Baja (and most other boat manufacturers) had a nasty little habit of leaving the in line fuse on the radio. You will have to pull the radio out of the dash to get to it. It is 3 amp I think. It is the white thing on the red wire in this picture.
Good luck.
Dan
[ATTACH=CONFIG]523721[/ATTACH]
Attached Thumbnails Baja Outlaw 36 - No voltage to the stereo-radio-dash-1.jpg
BajaDan is offline
Old 05-22-2014 | 04:03 PM
Thanks Dan! I'll give it a try.
marc9889 is offline
Old 05-24-2014 | 06:55 AM
My 98 has a rocker switch on the dash that turns the radio on....
rumrunner29 is offline
Old 05-28-2014 | 08:35 AM
F-2 Speedy's Avatar
On my 33 there is a 6 switch pannel in the cuddy on the left side with one marked stereo
F-2 Speedy is offline
Old 05-28-2014 | 08:36 AM
I hoped that was the case with my boat, but it's not looking that simple. I turned on all the switches and used a volt meter to check for 12v at the radio and I still have nothing. Worse yet, I took the boat to Panama City Beach over the weekend, so I won't have a chance to fix it until it comes home in October.
marc9889 is offline
Old 05-28-2014 | 08:38 AM
F-2 Speedy's Avatar
is this a new boat to you ? or it did work and now it doesn't
Old 05-28-2014 | 08:39 AM
It hasn't worked since I bought the boat.
marc9889 is offline
Old 05-28-2014 | 09:31 AM
sounds like you will need one of these and LOTS of D size batteries this summer
92nsx is offline
Old 05-28-2014 | 09:35 AM
Good plan... does anyone make bell bottom swim trunks??
marc9889 is offline
